Progressive 440's, are they worth the $$$$$?
I have a set of brand new Progressive 440 HD on my bike, I also did the front end, love the ride, but have a big problem getting the bike to the shop, I have 2 ramps and it wont clear the ramps, I need to get them off so I can get the bike into the shop in the backyard. these are the 11.5 drop shocks with HD springs. I will go to a air ride so I can raise the bike to get in the shop. I'll take 350 for these.
Just about all the 04 and 05 Screamin Eagle Electra Glide owners went with the Progessive 440s. The SEEG sits lower than a stock electra glide, so we had the shorter shocks. I think it was the same for the Street Glide of those two years.
Once you get the 440s adjusted, it's no longer an issue. I'm 220 lbs. and often have a tour pack and used to have a passenger a lot (till the 09 Street Glide that she now rides) so I went with the 440 HD's (heavy duty).
At four years old, and 40k miles they started leaking but Progressive rebuilt them for free (lifetime warranty, if you keep the receipt).
[QUOTE=Once you get the 440s adjusted, it's no longer an issue. I'm 220 lbs. and often have a tour pack and used to have a passenger a lot (till the 09 Street Glide that she now rides) so I went with the 440 HD's (heavy duty).
At four years old, and 40k miles they started leaking but Progressive rebuilt them for free (lifetime warranty, if you keep the receipt).[/QUOTE]
This is all true almost, I have 440's on my 03 I had bought them off ebay much better than stock, easy to change the stiffness great ride 2 up. the down side is the valving seems to be 1 way sometime you will get a solid thunk when the springs rebound also yes they have a lifetime warranty (for the original buyer as long as you have a copy of the receipt) if not then you can almost buy a new set for the cost ( they don't really rebuild them they replace the shock and use your old spring) here is a copy of a ebay ad I was going to buy but I need a heaver setup http://cgi.ebay.com/ebaymotors/ws/eB...m=330283209869 mayby this set will work for you.
