Installing new hinges
Just a heads up ! Installed my new hinges this weekend and I have to agree that they look awesome . When you get ready to drill the rivets out of the old hinges a couple of things to be aware of and each seems to be slightly different. Each rivet appeared to be pressed slightly different then the next, You need to make certain that the drill takes out the center of the rivet or you will end up with an elongated hole thru your tourpack. Be aware of the spinning because you will tend to apply more pressure which will heat everything to the point of melting your way thru the plastic. In other words if ya plan on having any cocktails or brews let your bud do the install and you hand him the tools or parts!
When you get ready to drill the rivets out of the old hinges a couple of things to be aware of and each seems to be slightly different. Each rivet appeared to be pressed slightly different then the next, You need to make certain that the drill takes out the center of the rivet or you will end up with an elongated hole thru your tourpack. !
And do you know this from experience???
![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
Don't feel bad I did the same fuggin thing.
![Wink](https://www.hdforums.com/forum/images/smilies/wink.gif)
