CB to walkie talkie, how to?
1. Is it possible to communicate my CB with the common portable 2 way radios in the market like Motorola talkabout?
2. If not, if I need to get a portable 2 way radio that can communicate with my CB, what specs should it have
Thanks
Go to Radio Shack, and get a handheld that operates on the frequency that your CB does (which is 27MHz). You can buy handheld CB radios that will work on the same frequency as the CB on your bike.
If you are wanting to do bike-to-car communications (like if your wife is following you down the interstate in her car while you are riding), she either needs a CB handheld, or she needs a auto CB radio installed (this is the better way, you usually can get more range (distance) if she had the auto CB radio.
To question 2 Get a hand held 40 channel CB
Radio Shack still sells a little 40-ch Cobra that's a nice radio (you can find it many other places on the Internet for about 30% less, though). Hand-held, 12v adapter, magnetic antenna for car use.
Amazon has a little Midland 75-822 that is very slick (I'd suggest the addition of an external antenna). Tiny little thing. Can be used both as a handheld or a dash mount.
They also sell a pure handheld Midland 75-785 for like $30 (but you'd have to still add antenna and a 12v chaerger).
Then there are some even cheaper ones if you look around eBay (but I'd avoid used equipment like that because you can end up spending a good deal on replacing old rechargable batteries....and sometims they can't even be found).
Your CB operates on a different radio frequency than what the newer radios like the small Motorola handhelds work at. Think of it this way: Imagine that your CB works like it was an FM radio station. Imagine that the small handhelds work like they are AM radio stations. You can't hear them both on the same channel. Not a very good analogy, but you are talking about two different types of radio frequencies. They are two different types of technology.
GRMS and FRS are the most common hand held frequencies these days. They operate on a frequency that you CB doesn't. there is nothing to be confused about.
If you just want to talk to another bike, then get a hand held CB unit, from Radio shack or such, if you want to talk to a friend in a car/truck, you'll be better off getting a car unit installed. if it's just a temporay thing, (like you're moving via the interstate) then an handheld will be fine
try http://www.sierra-mc.com/default.asp
