turn signal cancelation
I have a 2000 road glide. I bought it used. When I use the turn signals they don't cancel after the turn. Would anyone know how to fix that? I have a manual that shows a turn signal/security module. Is that the module that i would change? It is under the seat on the frame. I would apreciate any help I can get. Thank you
Unlike a car, turn signal cancelation is based on a time/distance/lean equation. The first and cheapest thing to try is to clean the metal fuzz off the speed sensor. It is bolted to the top of the transmission. This sends the speed signal to the module. If that fails, the module you mentioned may need replacement.
MikeLaPlaya
04-12-2015 08:58 AM
OldFenderGuy
06-04-2011 01:07 PM
