Internal Wiring of Bars
Old 04-05-2009, 06:40 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
IAMSWUTIAMS is offline
The clutch cable needs to be +6", and the brake line needs to to be a 26" upper line and 17" lower lines. On the brake lines it's easier to know what you need than what to add to stock.
Old 04-05-2009, 07:16 PM
BadPiggy's Avatar
BadPiggy
BadPiggy is offline
Originally Posted by gabulldog
Did you guys push the pins out with a small drill bit (backwards) or a paper clip or something that fits the connector hole?
I have a hunch that the OP may not be aware of this.....
The wiring connectors..unplug..remove the orange rubber ring..then there's an orange insert keeping all the pins in their respective locations.
That orange insert will come out. You may need to use a small flathead screwdriver to "pop" it loose.
Once this "keeper" is out...look inside the connector.
There is a "tang" for each wire.
Use that same small screwdriver, push the tang from the outside edge towards the center.
At the same time you're pushing this tang, gently pull on the wire from the side it's fed into the connector.
This will "free" the wire.
Be certain to write notes where the wires go.
Old 04-05-2009, 08:16 PM
NoKenDo's Avatar
NoKenDo
NoKenDo is offline
What do you gain with these bars?
Rise?
Pullback?
Old 04-05-2009, 09:59 PM
IAMSWUTIAMS
rise, pullback, and width. Check the spec's compared to stock
yokdriver
08-31-2014 12:37 AM
DJY
07-09-2013 06:04 AM
Mike650
04-24-2012 10:48 PM
iDodgimus
04-15-2011 11:42 PM
DrPlastic
11-10-2007 10:22 PM
Quick Reply: Internal Wiring of Bars
