Internal Wiring of Bars
I guess if I'm changing to chrome housings/switch covers it would be much easier to do this on the bench rather than do it standing up over the bike. I have my bike down to the frame/engine so time is not the issue. I have a June 1st hopefull completion date!!! Did you guys push the pins out with a small drill bit (backwards) or a paper clip or something that fits the connector hole? Thanks, I have got SO much help from this forum. gary
PS, The completion date is totally dependent on the $$$, I just can't start writing checks for stuff.
I took the handle bars mount and all off the bike, and mounted the whole thing to the bench, by drilling two holes in a piece of plywood , then screwing it to the bench ( so I wasn't left with two big holes in the bench). It worked great, leaving the bars loose in the clamps let me move them back and forth as needed.
Edit again:
I just happen to be doing this project this weekend. Her is the trick that gets my pins loose:
On the side that the orange rubber piece came out of.
Insert safety pin on in along side the pins on the outward side.
Flex Safety pin towards the inward side while gently pulling the wire loose.
Last edited by Zacharia_11; 04-05-2009 at 02:53 PM. Reason: spelling & mixup on inward vs outward
