Installing HD security module
If you are talking about the security light on the speedo, it will stay on while the bike is in active mode until key fob is present and ignition is turned on. After the bike is started the light should turn off. I believe your bike came from the factory with the security system already right? If you are just installing the siren then nothing else needs to be done except to plug it in and make sure the antenna is routed properly as not to have it resting on any part of the bike that is metal. Hope this helps.
