Help with replacing tank
Old 05-01-2006, 07:43 PM
ScooterGuitar's Avatar
ScooterGuitar
ScooterGuitar is offline
Default Help with replacing tank
Any idea of why or what I would need to put a newer tank on my '98 FLHRCI? Most fo the ones I see and like are all for '99 and newer. I am sure one could be made to work, hoepfully easy. Just curious as if any techs,e tc would know?
Thanks
Old 05-01-2006, 11:00 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Shovelhead Bob is offline
Default RE: Help with replacing tank
You can ONLY USE a tank for the MM system (up to 01)
02 and on are the Delphi systems.....
MM have a dual fuel line set-up...
Delphi is a solo....
Old 05-02-2006, 12:04 AM
ScooterGuitar
Thanks Bob. Most replacemnt (stock HD replacements at least) say it's up to '98, then '99 up. Was the MM on Kings up to '01?
Thanks man
Old 05-02-2006, 12:15 AM
Shovelhead Bob
Fittings changed a bit in 99... You can get away with fabbing a later tank to a newer bike....
But not Vice-Versa.....
All MM went up to 01....
From then on....
Delphi...
Lori J. Welch
08-26-2018 03:49 PM
Vrooom
05-24-2011 06:10 PM
swaite
06-02-2008 01:03 PM
wydopn231
04-03-2008 01:19 AM
fathogg
11-10-2007 12:29 PM
Quick Reply: Help with replacing tank
