Heat Deflectors
08 FLHX with driver adjustable backrest. I am using the HD one, left side covering the adjusting lever. But I can easily lean forward and reach under the shield to get to the adjusting level. It's a good 2" gap between lever and shield.
Fiddling with it, I think I can take the lever assembly out of the mounting bracket and mount it on the heat shield. Doesn't look that hard to do, and the HD shield looks rigid enough to support the assembly. But since I adjust the backrest to one position, I never have to adjust it yet. Maybe next winter's project.....
I have RJ Origionals on my flhtcui and they do a wonderful job.
I looked at Kurkyans first - talked to a guy that had them & he didn't recommend them. He broke several as his chaps caught on them when dismounting.
Also, have the adjustable drivers backrest - just takes a moment to move the sheild to get at the backrest lever.........no big deal.
Ride Safe, Mike
You can't see the adjustment toggle from the side of the bike and it's still fairly easy to get to. After a few uses while at speed it's become an easy target to find without even looking down.
If heat is a problem give us a look we are a new sponsor here but have been here a while..
Our heat shields our Crotch coolers as we like to call them work very well and the quality is #1,easy to install.As with all of our products if you are not happy just send it back for a full refund. Here is a link to our page
Thank you
Larry
Thank you
Larry
