Crease on back of front fender??
I installed a FLST front end on my Super Glide about a year ago. Last fall I installed an engine guard.
Not long after that, I noticed there was a mysterious dent across the back of my fender between about the 10 O'Clock and 11 O'Clock position (when viewed from the right side).
I was recently told that it was on account of the front end bottoming out and coming into contact with the horizontal member of the engine guard.
I am trying to ascertain how common an occurrence this is and if there's anything that can be done about it -- other than watching the road conditions more carefully to avoid bottoming out the front end.
Any experience or tips are appreciated. Thanks!
R/
Priest
R/
Priest
Well, i'm not sure how "common" it is, but it happened to me. hit a pot hole doing about 60 on the freeway and bottomed out my front fender. One of these days i'll get around to fixing it. heavier weight fork oil has improved my front suspension, and i haven't had occasion to bottom the front out again.
Actually, I am using a 'touring' type engine guard (on a Dyna) ... it fits, but part of the 'work around' is it only goes outside of the top bracket ...!
Guess maybe I'll just have to use heavier fork oil and exercise greater caution ....
I wouldn't think that an inch or so would've made much of a difference, but that may explain it ....
R/
Priest
Sorry to hear about your front fender, but let me tell you....you really did a nice job mounting that front end on that Dyna. It really looks great! I did the same thing on an FXSTC a few years back. Had to change the tripple trees, and converted it to a Heritage front end. And I really like that bike. Well done! Heavier fork oil, and/or a 1 to 1 1/2" spacer plug inside, on top of the springs.
