Street Glide LED mod with Pics
PN 4015-10. Here:
http://www.customdynamics.com/flex_led_array.htm
Excellent customer service by the way.
Would it possible to mount the new LED strips along the back of the housing instead of the bottom? This way the LEDs would shine straight out?
Also if you did this to one of the new ones that already have the run/brake could you just cut off the plug from the old board and wire the strips into that plug or would you also have to add the Dual element circuit for each strip?
I edited the post with the wrong PN.
The housing is curved across the front so its depth varies being the shortest at the ends and the deepest at its center. Using the 3 30 LED strips I used barely fits along the roof of the housing. Anything longer and the ends of the front strip would project out from the housing preventing the lens from fitting to the housing.
Also, to use the full width of the housing roof, the molded plastic channels at the ends would need to be removed. Since they are a "C" channel, they won't snap off like those brackets between them did, but a Dremel with the grinding attachment would probably remove them easily.
As for the HD run/brake connector, it already has three wires in it and could be used for this application. Using dual intensity LED's, however, is something I'm not familiar with and you should call Custom Dynamics and ask them about that application. Sounds promising.
As for mounting the LED strips along the back of the housing to face straight out through the lens, there is only .5" in height which would not be enough to mount two of these 30 LED strips. But you might find some other LED product that you could mount there.
Give Custom Dynamics a call and see what they have to say about their various LED products and their useage in this application. I didn't, but encourage others to do so. Unlike bigmeanie's installation which curves/arcs the LED strips, my application mounting the strips to the roof of the housing doesn't take advantage of the flexibility of the strips, so there may be a more cost-effective and/or brighter LED product if flexibility isn't a concern. Build a better mousetrap and tell us about it.
WAit til you see it installed!! They will be bright!! I have over 200 of the same LEDs as brake/run/turn and reg turns on my Vrod.Super bright!!! I had to custom make mine also!! Made a plate under the edge of the seat and the strip light from the edge of my seat!! Really bright!! CAn't wait to see finished pics!!!Custom Dynamics is #1!! Lil pricey ,but well worth the price!!!
