What is the best trans and primary oil?
Old 04-01-2009, 01:18 AM
mike5511's Avatar
mike5511
mike5511 is offline
Originally Posted by 1FLTRI4ME
Actually there are at least 2....Heavy and Lightweight.
So which one is right for the HD tranny?
Old 04-01-2009, 05:59 AM
hpfatboy's Avatar
hpfatboy
hpfatboy is offline
That's just it, there is no wrong and there is no right. Every one has there favorite oils. I like 75-90 gear lube in tranny, 20-50 in engine and 10-40 in primary. Ask 10 guys get 10 answers, it's your call!!!
Old 04-01-2009, 06:09 AM
sooie's Avatar
sooie
sooie is offline
20/50 royal purple in all 3
Old 04-01-2009, 06:28 AM
HDJIM1158's Avatar
HDJIM1158
HDJIM1158 is offline
AMSOIL 20-50 MOTORCYCLE OIL in motor
AMSOIL 10-40 MOTORCYCLE OIL in Primary
AMSOIL 75-90 Heavy Gear in Trans
Been doing for years......never had a problem Be Safe JIM
Old 04-01-2009, 08:48 AM
FX4's Avatar
FX4
FX4 is offline
Heavy Shockproof.
Old 04-01-2009, 09:17 AM
bigskyhd's Avatar
bigskyhd
bigskyhd is offline
Redline Heavy Duty Shockproof in the gear box... Doesn't matter too much what you put in the primary. Any decent lubricant will handle that.
Old 04-01-2009, 09:30 AM
heavy K's Avatar
heavy K
heavy K is offline
i run
redline heavy shockproof in the tranny (its the best)
plain jane oil in the primary
syn 3 in the engine
Old 04-01-2009, 09:57 AM
Rubbit's Avatar
Rubbit
Rubbit is offline
Amsoil engine and Trans. Had the dealer do it at 1000 mile service. no problems.
Old 04-01-2009, 10:07 AM
RangeRat's Avatar
RangeRat
RangeRat is offline
A looooong time ago, I heard that a wet-clutch setup needed lubricant that was slippery when under low pressure but not so slippery when under high mechanical pressure (as when our clutch plates are engaged or in a cager's automatic transmission). Is there any truth to that? If so, then shouldn't we use the opposite type of lubricant for babbitt bearings, piston rings, gear teeth, etc. - i.e. still slippery even when under extremely high mechanical pressure (engine oil type)?
Old 04-01-2009, 10:10 AM
HDRider2002's Avatar
HDRider2002
HDRider2002 is offline
After doing some research on the forum, and i mean alot of reading, i've decided on Redline Shockproof Heavy for the Trans., Mobile-1 V-twin in the crank, and Castrol GTX 20w-50 in the primary. Seems the popular theory on the primary is it doesn't really matter what you put in there, just want to make sure it doesn't contain too much in the way of "anti-friction" additives so you aren't faced with clutch plate slippage. thats my $0.02 FWIW
harleylay
07-09-2017 05:47 PM
supernill
Oil Archive (no new posts)
02-15-2016 11:29 PM
PaUltraBob
2014-2023 Touring Models
07-13-2014 09:29 PM
toastman
27
07-12-2010 02:40 AM
Critter174
04-10-2008 05:58 AM
Quick Reply: What is the best trans and primary oil?
