sound deadning behind speakers work?
#31
You are correct in that the fairing is not a sealed environment, but I honestly couldn't tell you if air flow (while in motion) plays a factor in the distortion you're hearing.
My first thought would be to ask if you are 100% sure that you are comparing the same sound pressure levels...meaning are you sure that you're comparing the same volume sitting still, than you are while you're riding and hearing the distortion?
#32
It doesn't really add much weight either. We're talking ounces, more than likely less than what would equal a pound (that's less than 16 ounces for those that celebrate the 420 holiday).
Nice setup by the way GTS
#33
Pretty much. For the discerning ear, yes a difference can be heard. For the untrained ear, don't waste your time and money, spend it on chrome
The glove boxes converted to speaker boxes? Yes. Not by much, but I'll bet you'll hear a bigger difference from those than you will the fairing. Stuff those with Polyfill and you should be good. They still won't be air tight though, unless you get some made like what GTSDesigns showed us a while back. I wish I could afford to drop that kind of loot, but I'm bangin' on a budget.
started off like this:
ended like this:
#34
Terminator69
2014-2023 Touring Models
15
04-26-2015 09:50 AM
jeffreyjames
02-24-2008 09:21 AM
