I don't know the previous history on tensior changes on my bike. I bought it with 33,000 and pulled the cam cover at about 65,000 (about 18 months). The outer looked great, but the inner was about gone. I have since put another 13,000 on it and plan on looking at them when the bike hits 90,000...
I bought it last year with 4000 miles on it. I think 5000 miles in one MICHIGAN summer is pretty good!!!
WOW summer must only last about a month & a half in michigan my 05 e glide only has 90,000 on it i only put 20 k on it this winter gonna try to catch up this summer should be about 120 k by end of this summer . LOL
Doesn't seem like much more than that sometimes. I just need to figure out how to fasten a carseat to the back of mine and i'd be all set. Unfortunately i'm not sure how legal that is
I'm sure this thread has been beat to death, but I could use some advise.
I ride a 2000 RK with 9000 miles on her. I use Amsoil and do not hear any unusual noises. My buddy says that I have to get these replaced ASAP. I told him he's full of ****. Am I right??
I wouldn't worry about your tensioners until you get about 20k, even then all you need to do is inspect them. At 33k on my '00 RK my tensioners still had lots of life in them.
I would make sure that your engine has the upgraded rear cam bearing. Early '00 engines have a ball bearing on the rear cam, Harley upgraded these to the roller bearing as there was some problems with them. Check your VIN with Harley.
These are my tensioners after about 65K... needless to say I ended up replacing the pump, dropping the oil pan and generally just cleaning the bottom end out... Check yours regularly!!!!
