Anyone use the Rev Extended on PowerCommander V or III?
IAMSWUTIAMS and marsh, oinker02 has it correct. hit control+f after you have everything hooked up, then check the rev extend 6200 box and hit ok. that sets the rev extend up. By the way don't hit the " run app" or whatever it is called box, or it will tell you there is an error. Did mine today and going for a ride this weekend....
hdrider2002 you are correct about the update. The customer service rep said if you hit ctrl+f and then click ok, then that was all there was to it. I guess if its and older one, and it does not have the capability, then it will give you an error popup. I bought my pcIII in 06, and the upgrade seemed to take!?
I mainly know this because back when i first did my stage 1, i was going to either do the download or a pcIII, the "deciding factor" for me was the fact that the download increased the redline, while i couldn't do that with the PC111. Now that i have a PC111 with that cabaility, i'm much happier
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
