hi change out inner fairing all went well can not get lock back in i have the front forks turn left and locked i can un lock with srcew driver i think its out of time??????????????? help
thanks gabe
2009 ultra THANKS TO ALL PICS HELP A LOT FIRST TRY WENT IN GABE
On my '07 the key needs to be in the ignition and turned something like 60 degrees for it to drop down inside. Not sure if the '09 is the same way but...is the key in the ignition?
Often depends on how it was removed, in what position and that is what needs to be remembered and then returned the same. So if the ignition was in the off position then that is how it must return...I have a feeling you already know this, but hey it may be still worth saying still.
