Diamondback Brake Lines
03-30-2009, 05:52 PM
I purchased (from Zanotti's) the upper and lower Diamondback brake lines for my 08 Road King. The upper line arrived today and the lower lines are backordered until next week. Fine. My question is this. The instructions I received said to obtain the "new" lower brake line assembly which is the piece that joins all of the lines - upper and lower - together. Is this a separate purchase or is it included with the lower lines? I couldn't find anything on HD's site other than it said it comes with "all necessary hardware". Hopefully, this includes that piece. Anyone know for sure?
Thanks,
Gary
03-30-2009, 06:30 PM
03-30-2009, 06:34 PM
03-30-2009, 07:02 PM
03-30-2009, 07:56 PM
I changed mine out on an 07 SG...
From what I remember, the lower had the metal "Y" built into it. So you shouldn't need to buy anything additional.
03-31-2009, 07:52 AM
Should be the lower line.I bought the same lines for my 07 Ultra when I did Brembo conversion and didnt need anything else.
03-31-2009, 08:25 AM
If i recall correctly the Lower lines had the y attachment that splits the line off the master cylinder to the two calipers.
03-31-2009, 04:11 PM
Thanx, I was curious as I can't find the cable kit for mine.
03-31-2009, 04:48 PM
It's attached to the lower set ... mine was anyway. I believe the do this so you can fish the uppers through the fairing to the brake lever.
Big Twi$t
10-05-2018 11:45 AM
AngelAir
2014-2023 Touring Models
02-04-2016 08:40 PM
thatsalexus?
Touring Parts
02-25-2015 05:57 PM
ihbond
03-13-2013 12:31 AM
KSGLIDEGUY
01-10-2013 09:34 AM
