oil cooler install--needhelp please
have everything out to start install tonite of hd oil cooler. 2 questions! 1. instructions talk about 1 of 2 gaskets being supplied with kit. one has adhesive backing and one doesn't. don't think mine does because both sides appear the same. just seems like each side is a really "slick" covering. 2. there are 2 studs on the side of the new filter adaptor that goes against the mount where the oil filter used to go. the gasket has 2 small slots that i assumed went over the studs when you mount it. they do not fit nor if they did , the hole in the middle would be off. there is also a longer slot . need help here on how correct way to mount goes. thx
As I recall the studs fit through the slots in the gasket. The gasket will then be able to rotate a little each way on the face of the adapter. I was concerned that the gasket would have to be in a certain position for the oil to flow properly but I think that really doesn't matter. I did end up using a little Indian Head gasket shallac that you can get at AutoZone to work as a sealer and to keep the gasket in place when mounting the adapter. I installed mine a couple times because I had a small drip. The shallac cured the drip. You can get a 7/16 hex key at Harbor Freight also, but the quarter inch bolt and nuts work as well.
My original gasket was without the adhesive as well.
07, cooler, davidson, evo, gasket, harley, hd, hdoil, install, installation, installing, instructions, ironhead, oil, touring
