Idle RPM's - 2008 Electra Glides
I read this post about engine rpm's and its effect on "shake" and wanted to know what rpms you have your engine set at. Mine runs at slightly below 1,000 per the tach on the bike. Is there any way to adjust the idle speed or is that an ECM adjustment that needs to be done by the dealer?
Thanks for the input.
http://www.cyclespot.com/forums//showthread.php?t=21092
bump....would like to know this as well....an fi bike usually has a "throttle position adjustment assembly" that will adjust your idle.
an 08 or later touring model is TBW so I am assuming that it HAS to be controlled by the ecu OR via a fuel processor.
my service manual for an 08 doesn't list how to adjust idle. at least not at quick glance.
(ignore my ignorance....this is my first tbw bike.)
