Cams VS 103" conversion?
Like iclick did I added the SE255 cams only. I also ride in the 2,500-4,000 rpm range. I am very happy with the results. Not much difference in mpg except when using 6th gear, I got improved mpg there. I did end up with increased volume with my exhaust
If you are considering to allow a HD shop do the work here is an estimate:
$299 cams
$200 labor
$139 adjustable push rods
jim
$299 cams
$200 labor
jim
I am in the process of having an HQ525 cam installed in my 09 Street Glide; the bike will remain a 96ci engine. This is being done by one of the HQ guys (Kevin) who also runs one of the Atlanta area H-D dealer service departments. They also are doing the tuning of the bike. Results will be forthcoming.
I have a stock 96- SE211s Makes 95 HP 107 TQ as it is currently setup. Keep in mind the 255s are basically a high lift cam with stock duration.
103s performance for Dollar is low. To leverage them you need a head port and a better cam then a 255 IMHO. The right Cams in a 96 are a big bang for the buck actually spent.
$299 cams
$200 labor
$299 cams
$200 labor
Your HP/TQ numbers are excellent and the 211's are fine cams, which were on my short list. What is important to me is not so much the numbers, but where do they fall on the chart? If you're producing peak TQ of 107 at 4K RPM and 80 at 3200, you could have less TQ where you really need it compared to stock. One thing I can say about the stock cams with a good Stage 1 package is that they perform well in the low-end. The daunting task was finding a cam set that produced overall better numbers without harming those good low-end characteristics. That's the hard part of cam shopping. For example, I called Andrews and told them what I was looking for, mostly inquiring about their TW21. The tech I spoke with listened intently, then said "I really don't think we have a cam that will do what you want." Fair enough, so I moved on.
Like so many things head-work will help peak HP but usually at the expense of the low-end. Again, not everyone is after large increases in peak HP and it's all in what your priorities are. The guy from whom I bought my cams performed head work with the 255's installed and didn't like the result, saying it hurt the low-end performance. Instead of buying new or used stock heads he decided to instead go with the Wood TW6-6 with +4° gear, spending another $700+ that included a new 2-into-1 exhaust system. He's happy with the result but thinks it wasn't cost-effective and feels he lost some low-end performance, which he said didn't make sense considering the cost involved. He said in the range where he rides most of the time he didn't feel he gained much, although he said peak HP was much better. It should be.
