Another Clutch Adjustment Issue
While doing my 1K service, I adjusted my clutch. I follwed the service manual instructions to the letter...well, while I was taking the slack out of the cable to give me 1/8-1/16 (dime width) of play in the clutch handle, the cabel adjuster ran out of threads. So I started over bringing the cable adjustment nut on the cabel way up the treads before adjusting the clutch in the primary. This time I did not run out of threads, but instead stoped short, leaving about 3/16 or a little more of play in the clutch handle. I am sure that if I took it to a dime's width, it would have ran out of threads again. Am I missing something or doing something wrong? Also, the the adjustment nut being so close to the end of the treads, is their any danger of something breaking. Again, I followed the manual and I watch the videos on this forum and I did everything right...Thanks for the help.
2009 Vivid Black SG
2009 Vivid Black SG
2009 Vivid Black SG
2009 Vivid Black SG
Thanks, I did loosen the clutch cable adjustment nut to the point the lever touched the throttle, however, I guess I am doing something wrong because when I adjusted the clutch itself, it didn't take any slack out of the cable. As the manual says, I "lightly seated" the hex bolt and then tightened the nut around the bolt. What am I missing?
Adjusting the clutch pack shouldn't take any slack out of the cable. You are loosening the cable to begin with to take any pressure off the clutch pack itself. Once you loosen the lock nut, and adjust the set screw, then retighten the lock nut, you just need to retighten the cable adjustment. I think you are doing it right, just expecting something that isn't going to happen.
You're supposed to give your cable slack by adjusting it down by the front cylinder, then take your derby cover off and loosening lock nut and turn adjusting all the way in. Then, back out 1/2 to 1 turn. Then, re-adjust your clutch cable with the proper clearence 1/16 to 1/8 from the adjusting nut in the cable down in front of the front cylinder.
Will let you all know, once I figure out what to do....if anything...right now it is a lot better than it was, but still a little loose. Just don't want to tighten it down anymore because the adjustment nut will run out of threads. One other question, when putting the primary cover back on, do I need to use locktight or antiseeze?
