Any tips on V&H Dresser Duals Install?
I'm hoping to put my new dresser duals on this coming weekend. I have searched repeatedly for tips on the install (outside of the instructions) but haven't really found much. I have an '04 Road Glide w/ factory headers and SEII slip-ons. I'm keeping the slip-ons. I have new gaskets and everything I've read says to start from the back and work forward on the disassemble. Makes sense to me.
I guess what I'm looking for is info for the install of the new pipes and the on use of lock-tite (if needed), never seize (if needed) and tools that can be helpful etc. I'm relatively handy but wanted to get some input from the membership.
Thanks in advance for any and all replies.
jcain
jcain
Pretty straightforward install actually. Some will tell you to junk the V&H muffler clamps and go with Harley ones. I think you are fine either way as long as you conch the hell out of them. My one piece of advice would be to seat the mufflers onto the headpipes using high-temp silicone (Permetex Copper). It not only helps with leaks but makes it easier to get them off in the future. Being an 04, you don't have O2 sensors to deal with so you should be good to go. No need for loctite or anti-sieze.
When i installed mine this winter we went ahead and threaded the clamps through the heat shields before inserting the pipes. We then just opened up the clamps and pushed the pipes in and had no issues getting the clamps back together. If you have a friend around that can help, that extra set of hands can come in very helpful.
