Oil Comparison
Old 03-24-2009 | 03:55 PM
iclick's Avatar
iclick
Originally Posted by kromdom
not sure which is the ETERNAL debate: dino vs. syn. or .45 ACP vs. 9mm.
I use syn in the engine, dino in the primary, and .45 ACP in the tranny. Runs great.
Old 03-24-2009 | 03:58 PM
BadBobOk's Avatar
BadBobOk
I only use genuine whale oil in my primary. It's getting a little hard to find nowadays due to all of these PETA dipchits.
Old 03-24-2009 | 04:07 PM
flhtupser's Avatar
flhtupser
I run Mobil-1 v-twin in the crank and primary and Mobil75-90 syn lube in the tranny. Works for me.
Old 03-24-2009 | 04:31 PM
iclick's Avatar
iclick
Originally Posted by cbears
How do you guys make up your minds? My Harley guy told me to use the SE synthetic in both, made sense to me. I'm getting ready to go in for my 1000 mile and was going to use it. From what I read out here, everyone has their opinion and says theirs is the best. What I'd like to know is, is there anything wrong with just going with the SE synthetic in both like my HD guy says?
There's nothing wrong with that choice as an engine oil, but you could find an equivalent oil at a much better price. For example, Mobil 1 15w50 can be purchased for $23/5qt. bottle (<$5/qt.) at Wal-Mart, while the H-D oil is $11.30/qt. MSRP at your HD dealer. Likely no one that's knowledgeable of oils will tell you that Syn3 is a better oil, so my point is that although all synthetic oils are good, some are priced more sensibly than others.
The HD tranny is a gearbox, and being so it should operate with gear oil, IMO, which I find is what most riders use. The primary doesn't need a high-tech oil, IMO, and any dino engine oil 10w40 or higher viscosity will do fine, as will ATF or even a light gear oil (like Redline MTL). I steer clear of oils containing moly for the primary although I haven't seen any evidence to suggest that moly is categorically bad for wet clutches. However, moly content in engine oil is a big plus IMO.
Old 03-24-2009 | 06:34 PM
ballpeen's Avatar
ballpeen
DITTO>>>>>>>>> me too. I switched from Amsoil to the above, the bike seems to run quieter and cooler.......
Old 03-24-2009 | 06:48 PM
skratch's Avatar
skratch
coming up on my next oil change, and i'll be going with the m1 15/50 from wally world. last few changes around here have been with royal purple, no complaints with it, except that it runs about $11 qt.
for the primary, i like to use formula+, usually pick it up the same time i pick up a filter.
for tranny, i also use gear oil. except this last time i went with 75/140. in this la heat, that worked out real well for me so will be going that route again.
Old 03-24-2009 | 07:51 PM
wldbill's Avatar
wldbill
Cool
Originally Posted by malmax
just an FYI...Harley bids out for their "own" oil...do you think they put the highest quality product in their container...or does money and corporate decisions play here...just a thought.
Well my thought on this frequently offered argument is as follows: As the producer of thousands of motors a year with which is given a 2year warranty, would they really want the owners to be using an inferior oil that also carried my brand??? And while the warranty is only for two years, the reputation and good will for the brand extends for a much longer period.
Please, use whatever oil that suits your fancy, but don't knock the quality of a product based on such a poor rationale.
Old 03-24-2009 | 08:17 PM
Globeracer's Avatar
Globeracer
Default Mobile 1 or V Twin
When we talk about Mobile 1, are we talking about Mobile 1 or Mobile 1 V twin? Can regular Mobile one be used in the engine and Primary?
Old 03-24-2009 | 08:40 PM
madurodave's Avatar
madurodave
I tried the SE SYN3 in all 3 holes and did not like it. I use Mobil 1 90w140 in the trans and love it. I have Mobil 1 V-twin in the crankcase and have also used 15w-40 synthetic with good results. These just worked best for me. I do have SYN3 in the Primary so far with good results.
I thought the bike made more noise with SYN3 in the crank and trans.
Old 03-25-2009 | 08:55 PM
skratch's Avatar
skratch
mobile 1, not v twin. walmart sells it 15/50w in a 5 qt jug for less than 25.00. and yes it can be used in both.
drewcifer
Oil Archive (no new posts)
23
07-17-2017 10:20 PM
ltmdl90
05-05-2011 05:10 PM
mjaw
02-02-2008 06:37 PM
99superglide
03-29-2007 12:44 PM
jtfrog
18
07-24-2006 08:41 AM
Quick Reply: Oil Comparison
