Let there be light!
You might want to ck this thread out, where it seemed a lot of people here first got wind of doing the silverstars in all three lights.
https://www.hdforums.com/forum/touri...e-upgrade.html
I'm not sure what you have on an 08 as far as passing lamps. My '03 stock had the glass lens w/ the ridges in it, and the passing lamps were sealed beam, not removable. The headlight had a small crack in it, so I upgraded to the newer (like maybe 2006 ish or newer) smooth clear lens in the headlight and the passing lamps, so now I have removable bulbs, and can do the upgrade talked about in this thread, but haven't done it yet, but am planning on trying it.
If you look on the last page of this thread, you'll also see that I researched the H4ST w/ Sylvania to discover the new ULTRA is allegedly brighter and longer lasting than the H4ST, even in a motorcycle, has the same thicker filament, details on page post 117 https://www.hdforums.com/forum/4494556-post117.html
I didn't think to ask whether the Ultra was available in the 880's for the passing lamps, but guess you could shop around. May find better pricing online than in local store, YMMV
Let us know how it turns out if you try it. Also, FWIW, my theory on some lights lasting longer in the headlamp, I've seen many reports that those running a modulator (for safety/visibility during day time), which fluctuates power bright/dim to the headlight, actually get longer life out of their high performance bulbs, theoretically because they run cooler overall, but just speculation on my part about the stuff I've read.
wblockel
11
06-05-2006 07:55 PM
