Okay to start 09 EG classic in neutral w/o clutch pulled in?
How "New" is it?......I had this issue when I had mine and it had less than a few hundred miles on it.....Called HD dealer and they said when they are brand new they adjust the clutch to an extremely tight tolerance so that as it breaks in it will be set correctly....They said ride it fro a couple of hundred miles and try again.....Sure enough.....After a hundred miles or so it went away......Maybe not your issue but worth mentioning.....
Fortunately I have not, but I suppose as with anything mechanical nothing is impossible. I do recall accidentally tapping the start switch on my '03 Ultra which was in gear and resting on the Jiffy Stand. The bike lurched forward and I remember breaking out in to a cold sweat. Think I soiled my drawers too!
I have to agree with those that say this can't be a clutch issue. If the bike is in neutral, it wouldn't matter how far out of adjustment the clutch is or even if the clutch was not functional. It can't lurch forward when starting due to a clutch problem if the bike is in neutral. If the bike was in gear and you were holding the clutch in, then it could be a clutch adjustment issue.
Dennis
Dennis
ADD'l INFO: Bike also makeas a loud "clunk" at the same time as the slight lurch!
Thanks to all the replies! They have been very interesting and helpful. Just wanted to add that the bike makes a loud "clunk" at the same time as it lurches slight in neutral when I hit the START without the clutch pulled in. Maybe this would add some insight . . . hopefiully just a breaking in issue and not a problem. 09' EG Classic with 400 miles
As did my '75 Moto Guzzi Eldorado, but I grew to despise that feature on the not-so-rare occasions the bike would stall in slow moving traffic or an intersection. Trying to find neutral and get a 25-yr-old bike started in the middle of an intersection, on a grade, with trunks honking at you, is not fun.
I use the clutch. in neutral. for safety sake.
as far as your bike "lurching forward"-as far as I'm concerned it is NOT normal. Does it do it when the clutch is in as well?
if you have an 09 and haven't gotten the first service done yet then I wouldn't worry too much because the clutch will and SHOULD be adjusted at that time.
From that day on I do not start the bike unless:
1. Im sitting on it
2. Neutral
3. Clutch is in
4. Im paying attention
It was bad enough dropping a $4000 Yamaha. I don't want to think how pissed I would be if it was my $26,000 Harley.
Interlocks and safetys are nice, but as I learned from 15 years working around printing presses, you don't trust life and limb to them. (or a Harley drop)
casper gomez
09-03-2010 01:14 AM
