How to change oil at 60 mph..DON'T TRY IT
Well all that repiled had a look at dipstick....no the bike guys...anyway still had a little on the stick and about 1 qt in lower end will drain today to see if any shavings in whats left in there ,hope I dodged the bullit ....will probably flush it then refill.As far as I can tell just vibrated loose same fliter and oil for 2600 miles never seen it happen before.Went back and measured where il started 5700 feet found oil filter at 2100 feet.We will see.
Let us know, we're all on the edge of our seats on this one!
I'm not so sure about notifying the insurance company. I have read that any contact regarding your insured assets may trigger an increase (www.clarkhoward.com).
It would suck to "notify" them, have your engine be OK, and then get your rates jacked.
just sayin'
just sayin'
Well just got in from what was going to be a great day riding...Lost oil filter on bike and rode approx 1 mile before I noticed (No) oil pressure looked down to see oil everywhere......CRAP.Well just wanted any openions as to what I need to do now...Don't think I hurt it Temp gage read 210 -230 when I shut it down ,also have an oil cooler on it and use Mobile 1.THink I'll do a compression ck on it but just lookin for some advice from all you motor guys.......or maybe I can tell the BOSS(Read Wife)..Darn honey I toasted the motor now I need to put in a HQ113...and the trans is also screwed up now so we need a Baker DD6...Yea Right that will happen...Whell what do you guys think look'in for advice....Thanks
Wow... that could'a been real ugly if you'd of oiled up the rear tire.
Hopefully, you caught it in time and shut it down.
I'd do a cylinder pressure & leakdown check. If they, you're probably fine. As was also mentioned, cutting open the oil filter would not hurt, but you could still have wear issues that would not show up as debris in the filter... so check both.
If all is well.... RideOn! If not.... HELLO HQ113!!!!!!!!!!
Good luck... hoping for the best for ya!
Well drained oil out had half a qt in lower end will fill and fire her up today after work,keep your fingers crossed,Still dont know why it fell off,Had prob 10 oil changes on it plus the 2600 mile daytona trip...not a drip or anything and threads on old filter seem to be ok.This one is a puzzler ai'nt it.Thanks for all the suggestiong guess we will see tonight...Dave
Fired her up after through inspection...new filter new oil Hit the starter(Yea I said a prayer) oil pressure up to 32 psi no tickie on snap crackel no pop just sounds like it always does.Comp cked out in spec so i'll ride 500 then change oil again.Sending off oil sample tomarrow see whats in there ,did'nt see any metal in qt that was left but ya never know.
