"Stuck" rear Cylinder plug Help!
Old 06-11-2009, 11:50 AM
Raaze07's Avatar
Raaze07
Raaze07 is offline
Originally Posted by XTrooper3936
This one comes from careless people getting anti-seize on the base of the plug (at the top of the threads), and even on the electrodes. If you put the anti-seize where it belongs, i.e., only on the threads, you'll never have a problem. I've been using copper anti-seize on plugs for decades.
That's got to help -I suspect the copper anti-seize is conductive (since it has copper in the compound).
  #32
Old 06-11-2009, 07:07 PM
jag1886's Avatar
jag1886
jag1886 is offline
I would just use a thread chaser first, the threads are quite long on Harley plugs, you would be amazed at what they can repair good enough to work again.
You also need to be talking to your dealer as to why they didn't use anti sieze when they changed your plugs earlier, no matter what people here are saying here about anti sieze, you are suppose to always use it when screwing steel into aluminum, it's been that way for, at least 40 years, my plugs come out like they where screwed into soft butter at plug changes and it has been that way since the first L88 corvette I owned in the 70's!!!!!!
Steel and aluminum do not get along together that's why they dreamed up anti siezr!!
nevadarider
05-26-2019 07:18 PM
Rossi
04-12-2016 04:47 PM
HDF Tech
Engine Mechanical Topics
04-02-2015 05:56 PM
kucks12
Shovelhead
03-25-2008 08:38 AM
mtnlvr
Exhaust System Topics
02-04-2007 04:35 PM
Quick Reply: "Stuck" rear Cylinder plug Help!
