"Stuck" rear Cylinder plug Help!
Old 03-22-2009, 02:29 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
Originally Posted by tlb
take it to a machine shop, have them put a helicoil in it. you dont need to pull the head to have it fixed.
So do they vacuum the chips out from drilling and tapping?
Old 03-22-2009, 03:32 PM
MyRide7's Avatar
MyRide7
MyRide7 is offline
Don't think I will just put in the insert.without pulling the head...something about metal filings down the Big hole sort a "screes" me! What a bitch to happen just because some "pimpley face don't know their azz from a hole in the ground" 2 bit helper didn't or wasn't told to use a dab of anti-seize! this shat would get your azz fired if you worked for me.....Marty.
Old 03-22-2009, 03:37 PM
1flhtk4me's Avatar
1flhtk4me
Maybe a good time to do some head work and big bore!
Old 03-22-2009, 06:39 PM
miacycles's Avatar
miacycles
miacycles is offline
Heli-coils are great for repairing threads on something you take apart occasionally, however in a sparkplug hole we only use either a Keen-sert or a time-sert they are made of steel and last forever. hope this helps.
Old 03-22-2009, 07:11 PM
molsen's Avatar
molsen
molsen is offline
Personally, I would pull the head and get the Perma-coil spark plug heli-coil. It designed just for spark plugs. It is not cheap, but it does work alot better than you reg heli-coil. Around $30.
Old 03-22-2009, 07:25 PM
StreetGlider56's Avatar
StreetGlider56
StreetGlider56 is offline
OK here's the deal, turn the plug back in the hole untill it releases a bit, look for a product called n-force by BG products, (Automotive Shop) this is a foamming releasing agent... I've had really good luck with it on the 5.4 DOHC Fords that tend to snap the plug off in the head..
Old 03-22-2009, 07:38 PM
1931jamesw's Avatar
1931jamesw
1931jamesw is offline
I wouldnt think you would have to pull the head off. If you do though, maybe it is time for some head work and maybe even a big bore job!
Old 03-22-2009, 07:51 PM
Bingo's Avatar
Bingo
Bingo is offline
Default Whut I wuz told.
OK, don't bother getting the flame throwers out, I am only repeating what I have been told (read) here on the forum.
1: No anti seize on the spark plugs. They need to be well grounded to work well. This one didn't make sense as the plug will ground via the seat, but that's what was written.
2: Do not put a cold plug in a hot head. The head has expanded from heat and the cold plug could mess the threads up. This one makes sense and could be what happened if the dealer did that.
Just passing it along.
Old 03-22-2009, 11:23 PM
tlb's Avatar
tlb
tlb is offline
I have seen it done a few times over the years. I agree take it to a good machine shop that will use the best parts. When I have seen it done with the head on the bike yes they vacuumed the cylinder. I do not think it was their first rodeo. I watched a guy put one in my my dads bike in 1979. Is still runs with the same helicoil in the head.
Old 03-23-2009, 04:37 AM
XTrooper3936's Avatar
XTrooper3936
XTrooper3936 is offline
This one comes from careless people getting anti-seize on the base of the plug (at the top of the threads), and even on the electrodes. If you put the anti-seize where it belongs, i.e., only on the threads, you'll never have a problem. I've been using copper anti-seize on plugs for decades.
Quick Reply: "Stuck" rear Cylinder plug Help!
