LED Taillight Help
LED Taillight Help
Just installed the Kury LED taillight (w/o Panecea) and LED silver bullet turns. Installed the Kury run/turn/brake controller with it and brake, tail & directionals work fine, but when the directionals are just in run mode they flicker quickly. Added two load equalizers to the two pigtails on the Kury run/turn/brake controller and didn't do anything. Put back in the HD run/turn/brake modulator I had installed prior to having LEDs and directionals still flicker in run mode but difinitely less. How do I eliminate it? Tried splicing a load equalizer into the blue taillight lead on the line side of the HD modulator but that dimmed the turn signal taillight function to almost nothing. Do I have to live with the slight flicker and just leave the HD modulator in or has somebody ran into this and has some help?
The Badland's Illuminator or Badlands Load Equalizer will also solve the problem.
http://ridetimetechnology.com/modules.htm
Thanks guys. Few more questions:
Seems like I'll go with the Badlands or Biketronics.
1. Keep HD rune/turn/brake module and add Bandlands III or BT Smart equalizer. Would it go on line or load side of HD module, Badlands shows putting splices downstream of controller?
2. Install Badlands Illuminator in place of HD module w/o LE since its integrated into Illuminator. Eliminates the two modules and puts all in one unit. Long term?
3. The Biketronics Smart Equalizer has a few models; BT801, BT802, etc. Whats the difference? My scoot is an 07 RKC wired for security (red key lights in cluster) but don't have security installed.
Yea, not to happy with the Kury. Find them to be hit or miss on stuff. Lights look great lite, but LEs, controllers, etc., cheaply made but not priced cheap.
