Need a little help: V&H Dresser Duals installation...
As many times as I've changed pipes, I always forget how much I hate this job. Those rear jug exhaust flange nuts are so frustrating to get at no matter how many flexible, wobble sockets I use. But I digress...
I installed a set of V&H Dresser Duals and classic turndown slip ons today. Problem is that the left side head pipe is SO close to the frame that I cannot get my left side body panel back on. I think the problem is in the bracket for the left/rear pipe that attaches to the starter housing . The dresser duals require a new bracket there and you're supposed to re-use the stock post piece that attaches to the bracket, but there's no mention of how it's to be positioned and the picture is worthless.
For anyone that's installed dresser duals, do you recall or can you check how that post piece is oriented? If you look at the piece from the left side of the bike, it can be rotated 180º from 9 o'clock, to noon (straight up) or 3 o'clock (where mine is).
I'd appreciate hearing from anyone who's installed the dresser duals to see if there's anything I can do to reposition the headpipe. As difficult as it is to remove/install that rear pipe, I'd like to not get into a trial and error exercise.
Thanks.
Thanks.
Not sure other than to let you know I recently put dresser duals on my 08 SG and no clearance problems with the pipes themselves. The pics are hard to see in the instructions. Here is a link to a pdf file that may have a better picture of the rear support bracket. My bracket is oriented very closely to the one in this pic. Hope it helps.
http://www.vanceandhines.com/download/D435IN.pdf
