Progressive Front lowering kit
Has anyone installed the Progressive fork lowering kit recently? It says to remove the fork, which I did, I drained the right fork since this it says is the only fork I need to change the springs in? I have a 2002 FLHTC. So, how much oil should I add back in, and before that, I don't have the fork tube vise holder they reccommend in the manual, so does that fork top bolt have a torque spec? Also when I take that bolt off is it a two man job? Is it under spring pressure where it will take my head off? Just a little confused and the instructions and service manual are a little confusing.
Humph!? No reply yet huh! Here's some answers ...
Has anyone installed the Progressive fork lowering kit recently? yes, I'm doing it today
It says to remove the fork, which I did, I drained the right fork since this it says is the only fork I need to change the springs in? Hum? You should have two forks (unless one fell off) - drain them both! The Progressive Kit comes with two springs; change them both.
I have a 2002 FLHTC. So, how much oil should I add back in, Check your manual
and before that, I don't have the fork tube vise holder they reccommend in the manual, You don't need one, use a screw driver to hold the fork in place (on the bike) while you remove the 6mm fork bolt.
so does that fork top bolt have a torque spec? Yes, check your manual
Also when I take that bolt off is it a two man job? No
Is it under spring pressure where it will take my head off? No it is not, however, the bolt on the slider (where the spring is) is under pressure but not enough to hurt you if you are ready for it to pop up
Just a little confused and the instructions and service manual are a little confusing. Do a little research into many of the threads on this forum that show you step by step how to do this work inconjunction with your service manual. Here's one - https://www.hdforums.com/forum/touri...p-updated.html
Good Luck...feel free to ask other question when you get started
dgdamore
2014-2023 Touring Models
22
12-27-2014 06:45 PM
81FLT
04-04-2009 01:10 PM
