Changing Oil In All 3 Holes, How Difficult Is It?
I am about to take my 08 Road King in for it's first oil change and the dealer will be charging me about $160.00 to change the oil in all three holes. This money could be used towards the purchase of a J&S Jack that I really need to get. My question is: How difficult is it to change the oil in all three holes? I can manage an oil change in my vehicles and have done minor work on them as well. I do have the service manual. If any of you all know of a tutorial or link you can recommend, that would be much appreciated!
Thanks in advance for your help.
There's alot involved with the first service at 1000 miles. Oil in all 3 holes is just a part. Your best bet is to do it yourself. Keep your receipts for the oils, filter and o-rings and a log of service work completed. The job itself is very simple, so simple the Geico caveman could do it.
I felt the same way. I like doing most of the maintenance myself and they charged the same $150-160 just for the labor. I believe they also adjust the clutch, belt, etc. But still, I think I will spring for the service manual and do it myself. Although, the Syn 3 oil was $12.00 qt and my beast takes 7 quarts total.
The dealer said to get it serviced again at 2500 miles yet the owners manual says 5000 mi. What do you experienced guys do?
Mike
My salesman gave me a $90.00 off coupon so I felt that was a pretty good deal. The 1000 mi. service ended up being $150.00...
Mike
I have always changed my own oil and done all of my own work. The maintenance manual will walk you through all the steps....it is pretty easy.....even adjusting the clutch is easy.......just do it.....if you run in to issues log on and ask them here....somebody will answer them pretty fast that is what we are here for.....
I did my 1000 mile change today at 915 miles. I bought Harley filters online, picked the oil I wanted to use, and did it myself. The hardest part is changing the filter without making a mess. I haven't figured out a way to keep from spilling at least a little oil on the bike. I'll take it to the dealer for the rest of the 1000 mile checkup items.
Lots of people run into trouble with the torx screws on the derby cover by stripping them. Make sure you use a T-27 torx and an impact driver, than they will come right out and wont strip. Use a torque wrench in inch pounds for the re-install of the derby cover so you dont over tighten them.
I've changed my own oils several times and have had the best luck with a plastic bag over the oil filter to reduce the mess I make. I then clean the area after everything is back together with brake cleaner. I never even thought about using a 2 liter to redirect the mess into the catch pan where the mess is supposed to be. Thanks again.
THANK YOU!!!!!!
