Changing Oil In All 3 Holes, How Difficult Is It?
Mobil1 15-50 Synthetic $26.00 5qt. jug from Wal-Mart. Change every 5K miles.
Mobil1 75-90 Synthetic Tranny Oil $8.00 any auto parts store. Change once a season.
Castrol GTX 10-40 Dino $2.50qt for Primary from Wal-Mart. Using a synthetic is a waste of money. Change once a season.
HD Super Premium Oil Filters. I buy 6 at a time from either Chicago HD or Zanottis online @ 20% off. Your filter is the weakest link in your lubrication cycle, why scrimp on it? It has the best filtering rating of any filter on the market. Change every 2500 miles.
The "imag" is a parenthesis around (mag plug) indicating that it is a magnetic plug, which is the plug you want to remove for draining the oil.
As for the dead cat? Use your imagination.
Good one SOOS,
Changing the oil is a big pain in the ***..takes all day by my standards.....
I usually end up cleaning the whole bike wash, wax,leather treatment, etc for the therapy...
I only took mine to the dealer for the 1000 mile..after that manual and my garage since..
It is pretty easy to change it, but it's the afrter thoughts that hurt,"well I my as well clean it"
Changing Fluids
Like everyone is saying, changing your HD's fluids is so easy. For the oil mess created when removing the oil filter, I just use a thin piece of cardboard ( just like from the back of a paper tablet ) cut to a size of 6"x11" ( a light gage piece of sheet metal would work the same). Bend to a curved shape along the center line of the 11" length and slide it right under and all the way back, under the filter. Removing the filter = NO mess what so ever, the oil runs right down the cardboard and into your drain pan. I've used this same piece since day one, just wipe it off. I use the K&N oil filter with the 17mm nut welded on the end, makes an easy job with a socket to remove the filter.
Don't let your HD stealer tell you that THEY must do your first few or any for that matter, services, to keep your warranty in effect ! That is total BS ! Again like they have said here, I make each service entry on the blank back pages of my service manual with date, milage and brief discription of what I have done and type and make of fluids and service.
Doing your own basic service; fliuds, clutch and primary chain adj.'mt, front fork oil, brake fluid changes, plugs and nut & bolt tightening is fun and a easy way to make you more familiar and bonded with your ride. And while you are putting down the road, you feel good about knowing that "YOU" are the reason that your bike is running so great! You know the old saying; " if you want it done right, do it your self" ! I have the HD extended warranty, they can fix any problems, I will do the services. I have owned all the Goldwings, and my Ultra is SO EASY to maintain compared to the GW ! Craig
