dino oil
Old 03-20-2009 | 10:07 PM
beary's Avatar
beary
Originally Posted by sonar_chris
If your motor is burning oil, its not because of synthetic, you have some other problem going on. There is no way that burning any oil in a new vehicle will be normal, not with the strict EPA rules.
If you believe this, then you don't understand seating the rings to the cylinder. What do you think a break is means? Do a search on Google.
What does EPA have to do with it?
The silly thing about this is that dino oil doesn't hurt an engine at all, so why even risk it?
Beary
Old 03-20-2009 | 10:31 PM
SamStone's Avatar
SamStone
I've read so many arguments about synthetic oil. I've never read any negatives about dino. I'll be staying with dino.
Old 03-20-2009 | 11:08 PM
kromdom's Avatar
kromdom
is it OK to use regular unleaded gas instead of premium?
on a serious note (and to add fuel to the fire), pic below of sludge (care to guess if dino or syn was used). N.B. Car is a BMW 7-series
Old 03-20-2009 | 11:31 PM
jerseyjeff62's Avatar
jerseyjeff62
If you want to change your oil every 2000 miles you can use dino if you like to change every 5000 or more use syn oil,i use a good quaility oil and lucas oil add every 2000-2500 i change had no problem yet,but you'll get others that don't even think about dino oil no matter what i wonder do you guy that use syn in your bike use it in your car/truck too?
Old 03-20-2009 | 11:40 PM
Hoffy's Avatar
Hoffy
I have used Dino oil in everything for years. Had 257,000 miles on the Subaru. The cv joints and rack and pinion seals went out and the motor was running strong didnt burn a drop.
Had over 120,000 miles on my ford before I sold it, never any problems.
Always used dino oil in my honda crf450 race bike on 110 degree days racing in a series, never had a problem.
The fact is this, quality of oil is so advanced these days dino oil works fine. If you want to spend a s--t load more money for each oil change because it gives you some sense of security and you beleive in it than do it, nothing wrong with that at all. But you cant go wrong either way you go.
BTW, to all the folks that say the CVO 110 bikes come with syn oil, those motors have a base gasket leak problem we have all heard about.
Old 03-21-2009 | 12:24 AM
sonar_chris's Avatar
sonar_chris
Beary
I understand perfectly how rings seal in a motor. Gas pressure builds up during the compression stroke forces the rings outward against the cylinder wall. With over 150 psi in the cylinder, it wont matter what type of oil you use, the compression rings will seat against the walls and scrape the oil down the cylinder. That is the whole point of the compression rings, to keep cylinder pressure, gas and air above the piston and the oil below the piston.
EPA has a lot to do with your brand new synthetic oil burning cars. Do you really believe that the EPA would certify cars for road use that burned 1-2 quarts of oil every 5K miles? Get serious, all of your statements are made in a world of myths. Next thing your going to say is bearings skate with syn oil. Perhaps the world is still flat, and the sun revolves around the Earth.
Old 03-21-2009 | 12:35 AM
txfxstrider's Avatar
txfxstrider
Thumbs down
God I love these oil threads. (:
:rolleyes
Old 03-21-2009 | 01:37 AM
dhincc's Avatar
dhincc
Holy crap! Not ANOTHER freakin' LUBRICATION THREAD!
Look ... dino's aren't going to talk syn's into switching, and the same goes the other way around. PERIOD! Use whatever you like, it's YOUR bike!
Old 03-21-2009 | 05:09 AM
jpooch00's Avatar
jpooch00
This is reason #284,168,337 that dealer techs are considered to be totally incompetent hacks.
Best wishes,
John
Old 03-21-2009 | 05:10 AM
Jrsess's Avatar
Jrsess
Bottom line ,There feeding you a line of BS!!!!
Quick Reply: dino oil
