Bad Motor Mount?
Old 03-21-2009 | 07:33 PM
monkyman's Avatar
monkyman
And you checked the riser bushings as well, correct?
Old 03-21-2009 | 08:26 PM
run1fsr's Avatar
run1fsr
Is your bike a 2000 with the original motor mount? If so I suspect it is bad.
Old 03-21-2009 | 10:59 PM
Taterdog's Avatar
Taterdog
Didn't check the riser bushings, but I will tomorrow.
My bike is a 2000, but I'm the second owner and don't have the service history of the bike. I agree, if they are original it's probably time for new ones, but they appear to be in good shape and I don't notice any excessive shaking of the motor itself. I can feel it more in the handlebars than anywhere else. I'll keep looking.
Old 03-22-2009 | 08:41 AM
buggy's Avatar
buggy
Default bad rubber
I would replace the handlebar bushings with poly ones.I used to change front motormount every 10 k the center hole will egg shape, glide pro has a new one out also ive been told you can use a buell mount ,but i would compare them side by side first
Old 03-22-2009 | 09:52 AM
The Old Man's Avatar
The Old Man
How about the neck bearings. May need to be adjusted or even replaced.........
Old 03-30-2009 | 10:22 PM
Taterdog's Avatar
Taterdog
Just a follow up. It was the motor mount. The old one was cracked, I just couldn't see it without removing it. Rides great now and no more bump!
Old 03-30-2009 | 10:39 PM
Road Twister's Avatar
Road Twister
..did you buy a HD one..or did you use an aftermarket one?? tks
Old 03-31-2009 | 07:19 AM
Taterdog's Avatar
Taterdog
I just went with the HD mount. The old one had lasted quite a while.
Old 03-31-2009 | 08:15 AM
maineultraclassic's Avatar
maineultraclassic
What is the part number and price for a new motor mount?
I'm getting some vibrations lately and think it might be time for a new motor mount.
Steve
Old 03-31-2009 | 08:21 AM
dawg's Avatar
dawg
Steve
16207-79D $64.38 retail
