Passing Lamp Part Number.......
I was gonna pick up the bulbs the other day at the shop. They had a 20% off sale. I didn't do it because they say sealed beam and I could not figure out how to remove the bulb. Now I know the boot has to be cut, but I thought that it looked like it was solid plastic, not rubber. Any other options out there besides this? I am running the Silverstar in my headlight and have been getting about a year out of them.
68208-98A is the bulb kit that uses the H-3 bulb. Easy to find an upgrade bulb for it. This is also the "sealed" unit that you can remove the rubber seal to replace the bulb. Carefully, and then re-seal with RV. I was able to get H-3 bulbs to match my H-4 PIAA headlight. A pair of 55 watt bulbs Baby! Clear lens, they look very nice and match headlight.
Passing Lamp 2006 FLSTC-I
One passing lamp bulb blew. It is part number 68414-05. I am finding 68453-05 as a replacement part. Is this correct? I also found J&P Part: 504-623 at J&P Cycles, but it costs $45.00 more. Will this fit? I am looking to replace both bulbs with brighter bulbs. It appears that I can also replace the whole thing with J&P Part: 3100456 from J&P Cycles. Suggestions???
Mike Feller
Mike Feller
