EVO's have the sparkplug fire every top dead center ?? The EVO animation shows that. The twin cam fries only on the power stroke. Thats what it shows.... is that correct?
That is very cool. But that's a gear drive, right? Or are they just not showing the chain?
It is gear drive because the cams are turning in opposite directions. Chain drive, both turn the same way. The timing is the same, but the cam is ground exactly backwards so it can turn the other way.
The difference between dual fire and single fire ignition systems.
