Air Horn, Feedback Requested
#52
#53
Here is a link you may want to do a "Save As" to your computer if it does not work right.
It is the Mini Beast & the HD Premium Air Horn.
http://webpages.charter.net/robandlyn/1/horn.wmv
Rob ....
Rob ....
#54
I got mine here: http://www.thepropad.com/p-84-mini-b...r-horn-ii.aspx
It lists for $159.95
at the time I had pre-ordered it and it was about 6 or 7 months before it came out. They had a intro price of 149.95 and offered 15% off and free shipping if you ordered two or more so a buddy and I got them for $124 delivered.
Look around, may find it cheaper.
139.99 on ebay: http://cgi.ebay.com/ebaymotors/PRO-P...QQcmdZViewItem
#55
#56
#57
Ok here ya go, Mini Beast, Pro Pad, Stebel Nautilus , or bad boy are basically all the same unit. Bad boy from HFT is a knock off copy, main difference is whether they come with a cover and style of cover. For those of you that do not like the covers, you can remove the compressor part of the horn and mount it under the seat on pre 08 models and run a small rubber hose to connect the horn to the compressor, still use the stock hd cowbell horn cover. I have had a few of these and love them but they do have some problems. They as a complete unit do shake alot, you must secure the cover good to the horn even with the stock units. By remvoving the compressor you lessen the weight of the unit. Also make sure you add a bit of crimp to the wire connectors where they attach to the compressor, they tend to come loose. To modify these horns requires some fine tuning with a dremel tool. Here is the link to another forum that has a "how to"
http://www.cvoharley.com/smf/index.php?topic=6622.0
#58
#59
