Battery draining
Old 03-17-2009 | 05:39 AM
Whiskyb's Avatar
Whiskyb
Default Battery draining
On my Ultra classic my battery will slowly drain, are their any known issues that I should check first. It is charging well and has a new Odysee battery last year, but if I leave it for 3-4 days it will not turn over.
Thanks
Old 03-17-2009 | 05:44 AM
JayStronghawk's Avatar
JayStronghawk
Get an H-D Battery is none better ... The original H-D Battery on my 04 Sporty is still working well although gave it to a friend when it was 5 years old thinking time to replace it ... Still cranks over like it did when new...
Old 03-17-2009 | 05:46 AM
GLACIERPEARL's Avatar
GLACIERPEARL
Old 03-17-2009 | 05:48 AM
Maxcustody's Avatar
Maxcustody
Get a battery tender from Wally world they are cheaper and work just as good. HD charges you twice as much. When it is parked the battery tender is on it.
Old 03-17-2009 | 06:06 AM
Whiskyb's Avatar
Whiskyb
Glacier, thanks for those links thats what I needed. I really see no need to put a tender on something that is sitting for only a few days if even that long. Yes it gets one in the winter but thats all. A properly working system should not need to be plugged in everyday. As for the Harley battery being the best, how many different manufacturers has Harley used in the last decade?
Old 03-17-2009 | 06:43 AM
JayStronghawk
Well was not being a smartass just had goodluck with H-D Batteries seeing as you have an Ultra am sure means you have security and possibly a computer keeping track of other goodies as well if not a daily rider a tender may not be a bad idea.. Also I know most laugh at this try a piece of wood or hard rubber on the kickstand .. I use it and leave it a week without a tender and off she goes ..
Old 03-17-2009 | 06:48 AM
alame's Avatar
alame
sounds like a circuit/switch is on somewhere ? shouldn't drain after only a few days, what condition is the battery, cell gone bad ?
Old 03-17-2009 | 07:01 AM
skydoc's Avatar
skydoc
Could be a fault in your bikes charging system. Get into Barrie HD & get it inspected!
Old 03-17-2009 | 07:29 AM
mastery's Avatar
mastery
My 08 Ultra got a dead battery after letting it sit over the winter (it got pretty cold here). I got it charged back up, and now have a battery tender junior on it (about $25 from Amazon). No problems anymore, nicely charged whenever I want to ride it.
Old 03-17-2009 | 08:18 AM
piasspj's Avatar
piasspj
3-4 days and it won't turn over, you have a problem. It should be able to sit 3-4 months without getting that low (not that you should do this).
What condition was the old battery in? It isn't uncommon for problems to arise in the charging system if it is run with a bad battery.
Jennynicurn
16
11-17-2017 10:30 PM
Deuuuce
Electrical/Lighting/Alarm
14
04-30-2015 08:54 PM
Scarz
03-17-2010 10:50 PM
dkitch
05-24-2009 08:11 PM
tarheelrdr
01-18-2009 05:58 PM
Quick Reply: Battery draining
