Starting your bike in gear!!
#63
#65
My 2008 dyna super glide will not start in gear even if the clutch is pulled in. It will only start in neutral whether the clutch is in or out. If thats a problem, I wonder if its an electrical issue, my neutral light doesnt go on when the bike is in neutral either.
if it is the same as the touring line, did you have new levers installed? new grips? the levers have a 'tang' like on the brake side to depress the switch. no tang, switch no workee. if new grips, could be a pinched wire, or broken switch. if you didn't do the install, but the dealer did, take it back to them and have them fix it.
#67
I'll never forget when I bought my first Harley... the salesman was going over the bike with me and was showing me the starting procedure and he said that the starter would turn even if it was in gear and the clutch was not engaged… and then looked at me with a very straight face and said – “you’ll do that once”. Of course, he was right…
#68
#69
#70
Several years ago my Wife cranked the engine on her Dyna while in gear, clutch engaged, and the bike went down. Remarkably, she then picked it up by herself. I would add she is 5'9", 127 Lbs but VERY determined.
That can't happen with the current bike.
Eric
95 RK
07 RKC, (The Wife's)
09 RKC
Eric
95 RK
09 RKC
