Road Glide Headlights. Removing The Bubble
I've got an '05 w/the se bezel in. I also painted the inner at the same time. The bulbs/lights r the same, and if u look at the back of the housing, it is sealed w/a rubber gasket. I'm betting that if any water ever gets in there, i'll have much bigger problems than that! also changed out the bulbs for a blue bulb, but didn't go bigger watage. Again, if u look behind the faring, u will see that the wiring is very light guage, and a bigger draw bulb WILL cause problems IMO, so change out the bezel and enjoy
Lots of RGs with higher watt bulbs. NO problems.
Ursadorable
Screamin Eagle CVO Models
29
09-08-2018 06:59 AM
Ohio HD Guy
2014-2023 Touring Models
111
02-19-2016 09:27 AM
Sailrider 1
14
09-16-2015 12:13 PM
