how to fix a cracked hardbag cover?
Old 03-14-2009 | 06:27 PM
mikeroyharley's Avatar
mikeroyharley
Default how to fix a cracked hardbag cover?
i have a 5" crack on the lid of my tourpack how can i patch it so it won't get bigger?
Old 03-14-2009 | 06:38 PM
BanjoBill's Avatar
BanjoBill
Go to a Body Shop Supply Store in your area, they'll have acouple different 3M products that will do the job for you. They can give you a print out on how to use the product.
.....Bill
Old 03-14-2009 | 07:16 PM
Akitakoi's Avatar
Akitakoi
Buy a new one, about $60 for Black and a little more for colors.
Chicago HD or Zannotis
Old 03-14-2009 | 09:14 PM
bigskyhd's Avatar
bigskyhd
The real answer is to buy a new one. But you can drill a very small hole in the end of where the crack stops, to stop it from continuing, and then JB Weld the crack from the inside. That will probably hold it. Not necessarily pretty, but it can be sanded and repainted or touched up if you're paint savvy. Good Luck
Old 03-14-2009 | 09:22 PM
Lucky 13's Avatar
Lucky 13
You could use fiberglass on the inside of the lid. A fiberglass repair kit isn't to costly from the auto parts store and it's pretty easy to use.
Old 03-14-2009 | 09:28 PM
jdreed520's Avatar
jdreed520
+1 on the fiberglass kit, i just had to do mine. one of my hinges cracked around it.
BrandonSmith
Milwaukee Eight (M8)
19
01-14-2019 08:38 AM
trukr
10-23-2017 03:55 PM
bbqbrisket
Powdercoat & Paint
08-10-2015 01:23 PM
awilson40
12-12-2013 04:08 PM
HD&CUMMINS
11-05-2010 09:03 PM
Quick Reply: how to fix a cracked hardbag cover?
