Help - Find Power Inside Fairing
Old 04-08-2009, 01:49 PM
Harp_oon's Avatar
Harp_oon
Harp_oon is offline
Why not get the power directly from the battery, with a fuse on the wire? Should be pretty straight forward install. Where do You ground Your Amp? I had a noise on my amp when first installed. Turned out to be a bad ground, went with hogtunes amp, and harness after that, and the noise dissappeared. Ended up grounding directly on the neg on battery. Also check Yor ground on OEM stereo, might be the stereo that has a burned out ground. Might not hear the noise without the amp.
Hope this helps
/John
Bromano
03-12-2017 12:46 PM
DiscoBayJoe
04-25-2016 01:30 PM
Fire4Effect
Audio Systems
15
05-17-2013 07:32 PM
Volfan615
10-28-2008 01:09 PM
Smitty0128
06-01-2008 07:57 PM
Quick Reply: Help - Find Power Inside Fairing
