09 Detachable 2 up tour pak wont fit
Old 03-14-2009, 09:35 PM
Xcrossbow's Avatar
Xcrossbow
Xcrossbow is offline
I found with using my fingers that I was unable to "fold" the rear spring-loaded brackets on the mounting rack over the mounting hardware points in the rear on either side. I made sure they were lined up correctly and instead, I gently put downward pressure on the top of the tour box and they snapped in place.
Old 03-15-2009, 08:47 AM
uweldit's Avatar
uweldit
uweldit is offline
I hate to say this, but instructions for installing accessories suck.
Ask me how I know.
Accessories are an adventure. If you are concerned go by the dealer when i town next time and they will be happy to look at your installation and help you out for free.
Old 03-15-2009, 09:00 AM
murf1's Avatar
murf1
murf1 is offline
it's not the "side to side" fit thats wrong, if all I had to do was squeeze the bracket to get the correct fit, No Problem, easy enough fix. The Problem is the dimension from the front mount to the rear mount is short by 1/8 - 3/16 of an inch, like I said I have already cracked both plastic bushings, I'm just going to keep cracking them and take them back for warranty until they get sick of me and do something about it.
Old 03-15-2009, 09:25 AM
flyingace's Avatar
flyingace
flyingace is offline
Thats what I thought too. It was a LENGTH issue. But by spreading the bracket (widthwise) just a hair, (less than 1/16} mine slipped right into place. I know it doesn't sound like it makes sense, but try it before you give up.
BTW, which plastic bushing are you refering to (that you have cracked)?
Old 03-15-2009, 09:39 AM
FLoTR's Avatar
FLoTR
FLoTR is offline
That's what I was trying to get across. If he bought HD parts, that's all it can be.
Old 03-15-2009, 09:47 AM
lkr0's Avatar
lkr0
lkr0 is offline
I had the same problem, only I cracked both of them--now it fits perfectly---- easy to get on and off
Originally Posted by lp
Same issue with mine. I ended up just forcing it. Cracked a platic isolator too. Still works, just a major pain.
lp
Old 03-15-2009, 11:15 AM
murf1's Avatar
murf1
murf1 is offline
Its the plastic bushing thats molded onto each of the 4 docking points.
Old 03-15-2009, 11:18 AM
tda69's Avatar
tda69
tda69 is offline
License plate. Have you checked it? On my bike I needed to go to a laydown license plate in order for the TP to clear.
Old 03-15-2009, 02:25 PM
flyingace's Avatar
flyingace
Not an issue on 09 bikes. (or prev year Street Glides for that matter)
Old 03-15-2009, 02:29 PM
flyingace's Avatar
flyingace
Did you crack the rear one or the front one? Im assuming the rear one? Cause if you cracked the FRONT one, your problem is your trying to force the bracket on the wrong mounting post. The front goes on the plain metal (inner) post.
Not trying to insult your intelligence, its just I've seen that mistake made before on 09 bikes, twice in fact. (still cant figure out how they managed to get it ON the outer front posts)
Quick Reply: 09 Detachable 2 up tour pak wont fit
