HD Fog Lights
HD Fog Lights
I had these installed on my FLHTC. They provide a dramatic difference to the left/right lateral light that I can not get from the regular passing lamps. I had them installed independent to the high beam, so I can run these lights w/ the passing lamps. I decided to add these lights after a close encounter w/ a deer. The lights consume 9 amps. The way i figure it, with the new 50 amp system on 06 and up, there is no problem with power or battery destruction. You guys may want to consider these lights. I really do not care if oncoming cars don't like the added lights. All I care about is being seen and seeing possible hazards on the side of the roads.
hey russ, i'm near your locale... any pics of the install? did you hide the wires in the bars, or run em exposed?
where did you get the power from then? did you use the included switch, or wire in a different switch?
I have an 03 RKC, and bought the lights, but haven't gotten around to installing them yet, after seeing how much was involved. I don't have a fairing, so I'm toying w/ different ideas on the switch part. Some say put the included switch next to where my auxiliary switches are now, or some say use the extra accessory switch instead, but I get a lot of different answers on how and where to pull power from, and most of them haven't been specific enough for me to get my head around yet. And since I have exposed bars, I want to run the wires inside, which will take a little time to do it right, so just haven't gotten myself to start tearing into it yet...
08ClassicRider
Electrical/Lighting/Alarm
15
06-17-2019 09:18 PM
TriGeezer
19
10-06-2018 03:08 AM
