New Tour Pak goodies installed
Looks good Monster. Now clean you garage!
I drilled for both. Not difficult at all. Dont use template for rack. Cover area in blue tape. Place the rack so you can just get a finger between the rack and the passenger backrest. Make sure everything is straight and trace the feet on the rack. Check repeatedly until you're sure it's even and drill.
New hinges make you notice how crappy the old ones were. If the rack is mounted first you won't feel bad about placing the lid on a bench to drill it. (Put a towel down first.)I used an 11/64ths drill and I used tape to secure the gasket while drilling the holes behind it.
