FLHX toupack problem
Damn it, I need the lock so some bastich doesn't steal my KTP. Why does the lock not fit properly? I took the washer out and it still sits too far over and binds on the quick detach post. I have to say that I am becoming increasingly disappointed in the HD and on part quality or lack there of!
So thats 3 of us just on this thread not using the lock. Also I may be missing something but if you did get the lock to work how are you going to get the key in to unlock it ,seems it hits on the bottom of the TP and wouldn't fit.
Mustang Seats makes several different varieties of the "Ultra" backrest. I wonder how those are?
![](http://www.mustangseats.com/cart/images/mustang/harley/75324.jpg)
Smooth Extended Arm Wrap-Around Backrest, No Studs
$269.00
#75324 - Smooth Extended Arm FL Wrap-Around Backrest, no Studs
Road King 1994-2009, FLHT & FLTR 1997-2009, Screamin' Eagle 1997-2005, & FLHX Street Glide 2006-2009
Direct mounting to all FLHR King Tour Paks 1986-2009. Rubber washer mounting system eliminates the troublesome soft stock isolators. Arms are extended an extra 2" for added comfort. Thicker foam padding provides comfortable armrests. Mounts to 1980-1985 FL models when Tour Pack is relocated further back and drilled.
Note: Will not fit leather or chopped Tour-Pak. Will fit King Tour-Pak ONLY.
$269.00
I know its so stupid, I am told you have to bend the key to actually use it. I want to use mine and am thinking about taking it to the dealer and asking how to make it work.
$269.00
$269.00
No it is not the same Key cause I bought single lock when I put the detachable passenger back rest on when I first bought the bike. It's a different Key, and no that lock doesn't work either. The passenger backrest lock works like a dream. As far as getting the key to fit in the lock you don't have to bend it just have it off the key ring and take your time and you will be able to get it to unlock. One of these days I'm going to pull the saddle bags and with the TP mounted loosen all the mounting bolts to see if I cann't get the lock to align propperly. Till I find the time I'll just keep unbolting the lock mounting post. Sounds like its a running problem for this set up.
