RPMs
Old 03-09-2009 | 11:20 PM
odie-in-az's Avatar
odie-in-az
Default RPMs
Here's the question.. Your cruising at 55 mph holding steady. Are you in 4th gear at 2800-2950 rpm or are you at 5th gear 2350-2500 rpm.
Old 03-09-2009 | 11:45 PM
Beemervet's Avatar
Beemervet
That depends on the terrain and the wind direction.
Old 03-09-2009 | 11:46 PM
Beemervet's Avatar
Beemervet
Oh s****.................is this a trick question?
Old 03-09-2009 | 11:53 PM
Eyespy's Avatar
Eyespy
From: Southern California High Desert, here and there....
6th gear at 2000 rpm.
Old 03-10-2009 | 12:04 AM
sonar_chris's Avatar
sonar_chris
5th @55
Old 03-10-2009 | 12:22 AM
gunner11's Avatar
gunner11
5th if on cruise, if not could be 4th all the way to 3000 rpm's
Old 03-10-2009 | 12:29 AM
fairplay's Avatar
fairplay
some old fart once said "I can't drive 55"
Old 03-10-2009 | 07:59 AM
09StreetGlider's Avatar
09StreetGlider
For me, it depends on a few things. I ride to work every morning on a stretch of highway that is 55 MPH. I have about a mile to get the bike warmed up before I hit the 55 zone which is not nearly enough, even after a 3-5 miute idle after start up.
I did some testing this weekend and found that if the motor was fully warmed up (215-220 oil temp) I got the best response and fuel mileage by running around 2700-2800 RPM. However, when the motor is cold MPG went WAY down and so does performance.
I found it is better for me to try and stay around 2400-2500 until oil temps are 200 or so.
Optimal RPM will be dependent on many things....cams, engine size, compression, temperature...etc.
Old 03-10-2009 | 08:04 AM
gary_montague's Avatar
gary_montague
08 sounds best @55 in fifth gear
Old 03-10-2009 | 08:08 AM
dFREDb's Avatar
dFREDb
Anything over 55 and I'm in 6th.
Quick Reply: RPMs
