RPMs
Old 03-10-2009 | 03:37 PM
abate1's Avatar
abate1
5th at 55, over 60 then 6th
Old 03-10-2009 | 04:12 PM
Leftcoaster's Avatar
Leftcoaster
I've got a better question: You're standing in a room with a window. The window has a full southern exposure. After a few minutes a bear walks past the window. What color was the bear?
Old 03-10-2009 | 09:19 PM
garyhendley's Avatar
garyhendley
55 mph i am in 5th gear runs smooth -ride safe
Old 03-10-2009 | 10:10 PM
Bilboy's Avatar
Bilboy
Originally Posted by odie-in-az
Here's the question.. Your cruising at 55 mph holding steady. Are you in 4th gear at 2800-2950 rpm or are you at 5th gear 2350-2500 rpm.
If it's a newer bike, you'll know if your in fifth by the whine.
Old 03-10-2009 | 10:17 PM
09StreetGlider's Avatar
09StreetGlider
No whine on 09....hey did that rhyme?
Old 03-10-2009 | 10:26 PM
sonar_chris's Avatar
sonar_chris
White
Old 03-10-2009 | 10:53 PM
El Loco's Avatar
El Loco
To me theres a lot more goes into it than head wind . I also think about what kind of road Imn on and when Imn gonig to slow down or hit a curve I try to keep my RPMs above 2500 in twisties somtimes 3000 . but if Imn just cruiseing down the open road I stay about 2500 most the time or just above 2000. Usualy 4th gear takes me all the way to 55 or 60 never hit 6th till over 65.
Old 03-10-2009 | 11:01 PM
cardboard's Avatar
cardboard
Originally Posted by Korbenw7p3c
...lugging the engine causes premature wear on internals of the engine. I've never been a fan of lugging, but for me, if it's 55mph, it's 5th gear. My bike is always in the 2300-3000rpm range. It's funny though, my mileage is exactly the same doing 55mph @ 2300rpm's or 65mph @ 2300rpm's. You'd thing that with the added wind resistance @ 65mph, even with the same rpm's, that I'd get better mileage in 5th gear.
When you lug yer engine, which is usually tryin to operate it under 2000 rpms what you git is piston tilt. Ain't too good on the pistons. Should see a set.
If yer bike ain't got a tach on it you should git one put on.
Old 03-10-2009 | 11:19 PM
Texas Fat Boy's Avatar
Texas Fat Boy
What was the original question again? If a bear was going 55 and looking out a window ???
I don't understand.
Old 03-11-2009 | 10:00 PM
odie-in-az's Avatar
odie-in-az
I don't understand.
This one made me laugh out loud!
Quick Reply: RPMs
