abs on an 09 ultra
#31
It isn't a spongyness, it's more when you apply the brake the lever compresses about half way. Release it and re-apply and the lever works "normally". Like there's air or something, "space" if you will... Are other 09's the same? It isn't spongy, it's just the initial squeeze.
#32
The brakes are like this on three new bikes(09's) that two of my friends have and mine. When you ride down the road this does not happen only sitting still with engine off. I can't imagine all these bikes have this serious of a brake concern with no tsb's or recalls? I feel they operate normal but time will tell!
#33
update:
cured! i did 2 things. removed the pads and made sure the pistons were not hanging up , then.... bled the brakes numerous times (via a mityvac and the conventional way). after a lot of screwing around, it feels fine now.
rbt in mke
09 ultra w/abs
rbt in mke
09 ultra w/abs
#34
mine is the same way on my 09 ultra and wondered if was normal or something wrong. felt as if needed to bleed it. Guess will get to a dealer and make them do it....
#35
Sounds like yours need to be bled.
#36
#37
P'colaHarley-17RGS
09-16-2016 11:09 PM
